What software is this?
Make your master in the printer . Clean it up smooth it if necessary . Then make a mold and cast them like Tom did . I made the negative of the tire for machining the mold , but I forget what I did
![]() ![]() Once I figure out what I'm doing I'll get more precise with tread pattern. I'm sure a few "oops" will be along the way. But if they turn out I might be able to make a few for others? Do you know what products were used in the making of the actual tire? Rtv silicone? Pigment?
look for modelman's (Tom) 777 thread , he goes over the whole tire making . Or he'll see this and help you out
![]() I know my loader tires are made from latex rubber . you'll see it again on sunday . I got er checked out and greased for werk ![]()
The free stuff, autodesk123 design. I'm not too knowledgable with this stuff but from what I've found it works to an extent. From what I researched most are making a extrusion for treads on a different layer but with this I can't do that so I used the circular pattern and just increased the number till treds looked full.
