Old 10-09-2015, 08:42 PM
ricm ricm is offline
Default Re: Need help with semi truck gear ratios and front wheels
I don't know how fast a TA01 hummer goes....you'd have to back calculate knowing the gear ratios in each model, also taking into account the difference in wheel diameter...a bit more info about the TA01 and could work it out - motor rpm? Gear ratios in the drive train? Wheel diameter?
For the front wheel drive, get some super single rims from the container trailer or reefer....they have a hex drive like the standard rear rims
