Old 10-20-2015, 07:43 AM
Backlash Backlash is offline
Backlash is on a distinguished road
Default Re: Servo for raising / lowering tamiya landing legs
Tracy,
If you are wanting to manually control the servo, then maybe you could use a basic servo tester to operate the servo..??
Like this..
http://hobbyking.com/hobbyking/store...vo_Tester.html
Change out the rotary pot for a switch, and the servo tester should move the servo up and down, and HOLD it in the set position (either up or down).. A on/off/on switch would be a good idea to help save some battery power when the legs are up..
The only extra thing that you would need to do is add a battery pack to run the servo tester..
Mark..
Old 10-20-2015, 09:24 PM
Prodrvr2006 Prodrvr2006 is offline
Prodrvr2006 is on a distinguished road
Originally Posted by Backlash View Post
Tracy,
Like this..
Mark..
Just found a vid to back that up...https://youtu.be/keMeZypwN4g
