Old 10-22-2015, 10:40 PM
Default Re: JBC limited NZ
made a start on another project that has been sitting in the shed for a while now, the mighty KAT excavator.....
I know its lightly built and basically rubbish, but I think I can make it a little better than when it arrived.
The base was slightly bent and a little wobbly, just too lightly built.
a $80 purchase of a 3mm thick steel half sheet and the job begins
Im going to use the same set up as in the rc4wd excavator as I have all the parts already.
I have ordered 3 large ecs,s for the tracks and turntable , now its just a matter of making it all fit inside.
I used the original base plate as a template for the top half and reproduced all the other panels and welded them together to give it some more rigidity
wasn't happy with how the way the main boom rams were fitted , so added an extra mounting point to stop any possible twisting.
need to sort a few panel gaps , also instead of a counter weight at the back I may make a built in oil tank to save a bit of room for the electrics.
a new bucket and quick release is also in order as is rebuilding the track set up.
but first mission is to get it digging for the summer and the youngest will be happy.
basically I think I will be using the KAT as a template to build a whole new excavator.
Old 10-25-2015, 02:19 PM
So as it turns out the KAT is only good for a template..
made up a new set of booms out of 3mm sheet and welded them up.
I have predrilled the pivot points but will make up some brass bushes and stainless shafts.
This isn't turning out to be a ten minute job.
a little CAT code paint make it look better
add one new boom set up and a new steel bucket.
and the 4200's new look
cheers andy
Old 10-25-2015, 03:36 PM
Supermario's Avatar
Looking good Andy. Always nice to have a second digger. I really like the 4200 upgrades. The cat walks is a nice touch. Tracks look a little loose though?
Old 10-25-2015, 03:38 PM
Supermario's Avatar
I can't remember, do you have an interior in the 4200? And have you seen this? I just discovered a few days ago..
https://www.ttm-shop.de/katalog/arti...uer-ttm-bagger
Old 10-25-2015, 05:04 PM
cheers Mario,
yes the track tensioners need looking at, hopefully just full of dirt
I have seen that interior and at 89 pounds , nearly $250 kiwi that wont happen anytime soon
the cab on the 4200 is a cheap ebay special, quite a bit smaller than the standard but it came with a complete interior.
cheers andy
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
