Thank you for your offer re plans, I have downloaded Autodesk Fusion 360, now have to figure out how to download your drawings, not very computer literate. The pictures of your turntable look great.
Terry |
Hi Crusher,
Just click on the link and then save to your computer. Then start fusion 360 and select Upload and select the file you downloaded. To create a drawing from the design, you can do as in these tutorials: - https://www.youtube.com/watch?v=d4SY7RaL3K4 - http://knowledge.autodesk.com/suppor...4E837-htm.html Best regards, Stein :-) |
Thank you for your reply and help, I will give it another try. As I said earlier I am not good at using the computer so appreciate your help.
Terry |
I consider the project whatyou doing, a spectacular job Stein !
I am monitoring the project these to show. You will put the various phases of the project complete the excavator ? Best regards! |
Hi Marquez81,
Thanks! I'm not sure if I understood you correctly, but if you ask if I plan to do the same as this for the rest of the components of the excavator, then the answer is yes. (even if I'm in that phase of the project where it dawns on you just how much work that is left... ;-). Just got to make sure to have a little bit of progress every day, and it will get done eventually. ) Best regards, Stein :-) |
I started work on the upper frame and base:
![]() All the parts are milled from 6mm 6082 aluminum. The base is 10 mm less wide on all sides than the finished base will be. I'm planning on 3D printing parts that will go down to the same depth as this base plate, to try to avoid having to paint so much. ![]() The upper frame is put together with two middle parts perpendicular to each other and that slot into the sides. This gives the upper frame support in all directions. The sides bolt together with two 110 mm long M6 hex bolts (not shown in the pictures). ![]() ![]() ![]() ![]() ![]() The uper frame then goes onto the base. It will be fixed in place with an 20 x 20 x 2 mm aluminum angle bar, 310 mm long (not shown in the pictures). ![]() ![]() ![]() |
Stepping back a few steps and mounting the new slip ring, adding PTFE protective tubing to the drive motor wires and mounting the angle bars that hold the upper structure in place.
The PTFE teflon tubing is this one: - http://www.ebay.com/itm/111392849268 ![]() ![]() ![]() |
