Old 10-25-2015, 06:48 PM
Marquez81 Marquez81 is offline
Marquez81 is on a distinguished road
I consider the project whatyou doing, a spectacular job Stein !
I am monitoring the project these to show.
You will put the various phases of the project complete the excavator ?
Best regards!
Old 10-26-2015, 08:41 AM
Hi Marquez81,
Thanks!
I'm not sure if I understood you correctly, but if you ask if I plan to do the same as this for the rest of the components of the excavator, then the answer is yes. (even if I'm in that phase of the project where it dawns on you just how much work that is left... ;-). Just got to make sure to have a little bit of progress every day, and it will get done eventually. )
Best regards,
Stein :-)
Old 11-01-2015, 05:21 PM
I started work on the upper frame and base:
All the parts are milled from 6mm 6082 aluminum.
The base is 10 mm less wide on all sides than the finished base will be. I'm planning on 3D printing parts that will go down to the same depth as this base plate, to try to avoid having to paint so much.
The upper frame is put together with two middle parts perpendicular to each other and that slot into the sides. This gives the upper frame support in all directions. The sides bolt together with two 110 mm long M6 hex bolts (not shown in the pictures).
The uper frame then goes onto the base. It will be fixed in place with an 20 x 20 x 2 mm aluminum angle bar, 310 mm long (not shown in the pictures).
Old 11-23-2015, 04:45 PM
Stepping back a few steps and mounting the new slip ring, adding PTFE protective tubing to the drive motor wires and mounting the angle bars that hold the upper structure in place.
The PTFE teflon tubing is this one:
- http://www.ebay.com/itm/111392849268
Old 11-23-2015, 05:06 PM
Mounting the boom
I'm going to try to use electric gear motors first. If that doesn't work out, I'll make the excavator hydraulic instead.
I'm using some quite powerful gear motors for all of the joints.
Ebay link:
- http://www.ebay.com/itm/221515025957
These are 10 rpm 320 kg / cm stall torque motors. Two in parallel should produce 640 kg / cm.
The two motors mount to the upper structure with 8 M5 countersunk bolts.
The boom itself is constructed with two milled 6mm aluminum profiles. At the end, another gear motor is mounted with another 8 M5 countersunk bolts.
I bought the hubs on aliexpress:
- http://www.aliexpress.com/item/10mm-...922964248.html
I'm using gas springs where the hydraulic cylinders would normally go.
The gas springs functions in many interesting ways in this configuration:
- Equalize the weight of the arm, so that the gear motor only have to lift the payload
- Dampen sudden movements and protect the gear motor
- A sound that is similar to a hydraulic cylinder
- Visually resembles a hydraulic cylinder.
Item links:
- Gas springs: http://www.ebay.com/itm/181788326018
- Clevis: http://www.ebay.com/itm/161559757356
- Rod eyelet: http://www.ebay.com/itm/5mm-Female-T...-/181888111312
Old 11-23-2015, 05:13 PM
The stick consists of these parts:
- Sides in 3mm aluminum
- Hubs in 12mm aluminum
- Gear motor (similar to the previous ones)
Again, the gear motor is mounted with 8 M5 countersunk bolts.
Mounting the stick onto the boom:
Old 11-23-2015, 05:19 PM
The bucket linkage is milled from 12mm aluminum. The gear motor is driving the bucket through these links, so they need to be strong.
The pins are M8 x 80mm pins bought here:
- http://www.ebay.co.uk/itm/291511678072
