Old 10-30-2015, 11:26 PM
Default Re: JBC limited NZ
more progress, but I have a question .
Ive made some solid lines out of stainless tube to fit to the main boom, just sitting on there temporarily , but before I cut the plastic lines .
How do you guys seal the fittings on.
Ive tapped them at 5mm which is the correct size for my fittings , I will change the bottom fittings for right angle fittings, but do you use any sort of tread lock or sealant.
I have made some access panels to cover the ugly air vents, and will run a fan at the top of the engine cover to take hot air away.
cheers andy
