Old 11-09-2015, 07:36 PM
Default Re: Two hydraulic problems
Are you using the same oil in both models? Same grade & same type?
Hydraulic systems are extremely sensitive to contamination, the slightest spec of dirt/sand/rock will screw up a valve, block a fitting, scar a cyl barrel, nick an o ring. Do you have a filter between pump & valve?
Paired cyls - split the flow = slower response, but twice the power. No power? a blockage problem or incorrect valve movement.
Pump motor runs too hot b/c it's working too hard or running too fast. Use a lighter grade oil and/or slow down motor speed.
What ID plumbing is being used?
