Old 11-11-2015, 09:41 PM
rc_farmer's Avatar
Master Builder
Default Re: Magom Brushless Pump
Originally Posted by Digger_Bear View Post
Hi Rob,
I had another thought about the pump setup. I'm thinking about setting my system up so the pump only operates at same time as the valve servo therefore the pump won't run when no demand and should hopefully stop excessive pressure in that pipe between the pump and valve block.
I'm still trying to figure out how to program my radio to achieve this and yet to try so will let you know how it effects performance with any delay etc.
Ian.
I am using a 10g from Airtronics. I have the pump mixed with the valves so it only runs when demand is there.
I also turned the pump down to about 10-15%. I didn't know all this before you guys chimed in. Really appreciate the help.
Giving up is not an option!!!
Rob
