Old 11-13-2015, 04:38 PM
Rimrock Rimrock is offline
Default Re: plumping !
Hi, no it doesn't matter what goes where, just as long there are 2 hooked up lines between cylinder and valve. One can then reverse the servoes at the radio later, as needed. Likewise with the pump and tank lines into the end of the valve block, choose left or right channel freely
It's advisable to use thread sealant Locktite 542, or similar, on all threaded fittings.
Old 11-13-2015, 05:03 PM
stevec stevec is offline
stevec is on a distinguished road
Thankyou Rimrock for you reply top man !
Old 11-20-2015, 05:18 AM
Hi all Hydraulic working well but keep blowing the pipe before the prv saw order a Pressure Gauge but were dose it need to go !
