Old 11-13-2015, 10:58 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
While waiting for ScaleART to send me the right front axle, been playing with the alternative half fenders I have.
Just assembled it all loosely without cleaning up the sharp edges.
Figured it might look better with off-road tyres, installed the ones I have from the Arocs.
Old 11-14-2015, 01:38 AM
Tp_hofmann Tp_hofmann is offline
Tp_hofmann is on a distinguished road
Woooooooooooooow ... I am delighted to see your updates - please keep us updated!
Old 11-14-2015, 05:13 AM
chris1210's Avatar
chris1210 chris1210 is offline
chris1210 is on a distinguished road
Originally Posted by Rakthi View Post
Hi Chris, yes, the amount of detail on these Trilex wheels is unbelievable, as is the fit and finish. And yes, eventually the frame etc. will be painted red. The rear fenders will go in black but I might replace them with half fenders. Also thinking of replacing the rear suspension with the regular leaf suspension. Love the look of the air suspension but not appropriate for what I plan to do with this truck once it is finished. Still a lot of things hanging in the air on this build.
I agreed, the air suspension looks very nice on your truck. Is the suspension stiff or soft? What's wrong with it? I know you will haul a trailer so you need a stiffer suspension.
Hi Tom, I've been following your build on German site too. Did you run your Arocs Palfinger yet?
Old 11-14-2015, 09:33 AM
Rakthi's Avatar
Hi Tom, working on it. But not much time lately
Hi Chris, I will post some pictures tomorrow of the limited movement of the air suspension vs the leaf version.
This afternoon got some time and started on the fifth wheel.
Here the parts
ScaleART delivers with 3 different ground plates, one flat one, one raised one for manual operation and one raised one for use with a servo.
Also various nuts and bolts. The bits on the right with the long screws are for attaching the servo.
The actual parts of the fifth wheel
We begin with putting some stickers on the supports
Bolt the supports to the ground plate
Now place the moving / locking parts on the bottom side of the fifth wheel. The arrows point to the recesses where the supports will go. The circles are where the servo will attach later on.
Then the two parts are combined and held together with a cover plate. I made a picture beforehand to show this without the bottom plate blocking the view.
Here the finished assembly
The two stainless steel glide plates are supposed to be glued in place, but I just laid them in for now.
Next up is the prepping of the servo. The cable needs to be moved from the side to the bottom. Once that is done, the support plate is put in place (arrow), the long screws inserted and the distance piece and 2 nuts put in place. (the aluminium support plate needed the holes for the screws enlarged a tad - I ran a 2.5mm bit through them). The support plate is not mentioned in the instructions that came with the parts. I put the support in front, but in hind sight I think it would be better in back to bring the servo out a mm or so and give a bit more clearance to the servo horn.
Servo horn needs be cut to 11 mm
Servo mounted in the fifth wheel
Fifth wheel bolted on truck
Will take some pics tomorrow of the mechanism open and closed. Forgot those. Might add some silicone grease too and change the position of the servo support.
Tags
man tgx xl, scaleart, trailer
