Old 11-14-2015, 03:10 AM
Default Re: JBC limited NZ
no, pay pal is not an option.
get one from someone who has had lots of good feed back and all should be good.
the sprockets, I think they are 15 tooth, may be 50mm diameter sprockets, the hole grinder is only about 150mm long and I thought about scale, for a bit........used what I had.
If I add another sprocket on each side it will double the work load, and hope fully not the heat...
