more progress but a little slow.
made more brass brackets and fitted a solid line for the cables to power the grinder, and then run out of paint...... ![]() ![]() Need to do something about the wires on the bottom arm as I think they look like C@#$p. also want to widen the track base by about 15mm each side, will be easy enough to make some spacers up and longer bolts. But that's a job for tomorrow ![]() ![]() cheers andy |
today I finished the painting and cleaned up the cables on the bottom arm and installed two new toggle switches on the engine cover, 1 for the lights and the other for the grinder which is fused at 3amps.
also had to repaint the arms due to the new colour matched paint was different, spoke to the paint lady and she said sorry and gave me two cans for the price of one ![]() Then I made up some spacers for the track bodies, 15mm wider on each side. this has now caused me another problem, as it only just fits on the lowboy ![]() I need to rewire the track motors now because the cables are too short, and I found out why I blew a track esc, wires way too short and shorted together ![]() ![]() pictures. ![]() ![]() wider track setup ![]() and the problem Ive created ![]() ![]() cheers andy |
well Im back,
had a small problem with a truck load of lightning . basically it blew all the telephone jack points off the wall, fried the big TV and all other associated electrical things on that circuit, melted the TV aerials, toasted the wifi modem ect ect. the insurance company loves me now, but at least nothing caught fire. So, with no internet or TV I headed to the shed. have been playing around with the grinder and need to make a few changes, I need bigger sprockets as the motor bottoms out too soon when grinding, also ordered a quicker motor. Will try the bigger sprockets first and see what happens. heres a quick video of the grinder at work, and a little taster of another idea I had, this needs some more internal work and more speed , but I think I can get it to work https://youtu.be/FiQGex7iBOU cheers andy |
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests) | |
