Old 11-17-2015, 04:21 PM
fvasileios fvasileios is offline
fvasileios is on a distinguished road
Default Re: Scania my first build
Congrats on your purchase...enjoy your first build...
Once I did my first truck I always looking forward to my next...
Bill...
Old 11-17-2015, 04:44 PM
gismow's Avatar
gismow gismow is offline
Hi,
You should replace the standard motor. The motor is too fast.
In addition you must modify the front axle, it must be mounted in reverse, the track rod must be behind the axle, not in front of it. To do that you must build a new rod to not touch the gear box. Alternative you can lift the gear box at the front mounting points by placing a screw nut between the frame and the gear box holder.
After modifying that you can place the stear servo in the front next to the gear servo, as it is done in the us trucks.
Greetinx
Peter
