Old 11-18-2015, 10:18 PM
Nikaem Nikaem is offline
Nikaem is on a distinguished road
Default Re: how to help
Originally Posted by TRUCKMAKER View Post
Its nice that your doing this, but every link takes you to a sign in to the scale builders guild. If your not a member of that forum your not going to be able view any of the links. You might want to state that up front before posting it
good point
if you are interested I can email you the whole book
Old 11-20-2015, 06:58 PM
Default Re: how to help different list
this is the list so far I think I will have to do more than one book this first 97 is over 350 pages so when I hit 100 I will start another file. just gets far too large to navigate effectively. each how to or tipis it's own file as well so that is taking time as well. I still have to get some of the credits straight but it is going really well I think. I guess it would have been prudent to ask each poster for permission but this is all off the net so I hope it is ok. and I am trying to make it easier for all members of the hobby to find info. If a certain one peaks your interest I will send a copy of the file to you just ask.
1. Making marker lights & lenses from scratch By 3SPDREKR
2. Wiper blades By DWJL511
3. How to make scale looking hubs in 10 minutes!!! By cruisi @ scalerc 4x4
4. Make your own axle wideners By 1badxj @ scale rc 4x4
5. Hacking a Servo by the seatle robotics society
6. screw drives from 360 rotation servo by jigglepin @ scale rc 4x4
7. How To: Narrow Wheely King axles. By Hairball 11 at scale rc 4x4
8. Howto: Wheelyking Crawler
9. spoon to shovel By constant thread @rccrawler
10. traffic barrels from yogurt cups By Genetix_drifter @RCCrawler
11. hula dancer By stopmojim @ RCCrawler
12. Cheap DIY CB Antenna! by JBLKing @RCCrawler
13. Welder by by Rolandrockshop @RCCrawler
14. Welder
15. CB whips cheap and easy By jblking @rccrawler.com
16. a easy weathering tutorial tex50613@scalerc4x4
17. Big rig tranny with two outputs without a lathe By By Rikpal@ scalerc4x4
18. fuel can
19. cotter pin shackles
20. rock rash" how to By rolandrockshop @ RCCrawler
21. Another fire extiguisher built By elaz @ RCCrawler
22. low cost 3 link with servo on frame conversion By500swmag scalerc4x4
23. How-To: Scale Glass packs by Klowd13 @ scalerc4x4
24. How to make a Thermos By FLB @ RCCrawler
25. Scale ice By Haas5999 @scalerc4x4
26. Making a cooler
27. Build your own Smoke generator By Outcastrc @ scalerc4x4
28. 3 Stages of Hardbody Paint Weathering By R|M|D Photography @ scalerc4x4
29. Simple dimples By jeepman98 @ scalerc4x4
30. High $$$ paint job look on a budget By crashaholic @ scalerc4x4
31. How to bring a 7inch figurine to life!! By airwolfie @scalerc4x4
32. EZ Clod Grill Mod - remove that 4x4x4 By OldSchoolRC1 @ scalerc4x4
33. Wheely king axle narrowing (part 1) By zukamini
34. Clod 4x4x4 grill modification By hawmt@scalerc4x4
35. How to make anything out of styrene Old Busted Hotness
36. Porta Potty By SonoranWraith
37. Alternate Method of Repairing Cracked Body Parts By PrpHed
38. Work stand home made By OuttaLuck
39. body clips how to By little bob
40. Step by step Realistic Paint Chips and Wear with Salt by: Kris
41. Free F350 Bumper Plans by 65efi5.0
42. How To Custom Drive Shaft By Tamiya Cowboy
43. RPM/Volt =land speed of Various Motors By EeePee
44. How to make nice greasy mud by radcore @ RCCrawler
45. 6 minute soft top By Arctic Fire
46. Re: Whip antennas By Drail
47. Wraith axel narrowing
48. leaf spring tune up By chino63
49. How 2Beers Carves wood bodies By 2Beers
50. Homemade Scale Chassis By JoeMotor
51. Hooks for all
52. tooth brush sander
53. solid link on IFS? pantablo @Rccrawler
54. Shackel or clevis how to make easy by Nikeam@scale RC4x4
55. Adjustavle strap by wisdom rcsparks
56. cc01 tech stearing
57. fenderwells By GGuuyy
58. fishing poles By wisdom rcsparks
59. How To Make Custom Signs
60. How To Make Your Own Scale License Plates By Johndeerkid
61. No sew tire cover by Monkeybake
62. inner fenders for dingo By Juswin24
63. Gas can weathering By mygolfisslow
64. LED Resistor chart By Nikaem @scale RC4x4
65. shock ball end upgrade by Jackel @ beat your truck.com
66. Max shaft up grade for Axial shafts By Loiterer @ beat you truck . com
67. rock gaurds by @ beatyour truck .com
68. finding a servo horn BY CHRIS @ BEAT YOUR TRUCK.COM
69. how to axial links bysek494@ beat your truck.com
70. tap and drill chart BY CHRIS @ BEAT YOUR TRUCK.COM
71. DIY Bungees By ethernectar@ rccrawler.com
72. My DIY Driveshafts By Dr.thunder @ Rccrawler.com
73. Home made tire-hangers by DragsterDragons@beatyourtruck
74. Fuel Transfer Tank.for OFF-ROAD Diesel Fuel by FATBOYrs10@ rccraler.com
75. Another Tow Rope How-To... By micro racer@ rccraler.com
76. Aged Paint by madhatter @ scale builders guild
77. Alternate way to mount body By Fox @ scale builders guild
78. Axial wraith lower links, make your own By Jeepfixer1@scalebuildersguild.com
79. cutting brakes by BadJeepBruise @ scale builders guild
80. Easy Scale Sleeping bag–Tutorial By Mr Zippy4444@ scalebuildersguild.com
81. How RC Servos Works
82. Gauge Faces by MikevIllina@ scalebuildersguild
83. How to make small scale BUNGY CORDS!
84. JKRC Painting 101 - Detailing the Wild Willy Head By unglewd @/scalebuildersguild.com
85. JKRC Painting 101- Painting the JKRC Scale Driver By unglewd @/scalebuildersguild.com
86. Keep your towrope handy by Northkona@ Rccrawler.com
87. Late model defender front bumper By Inittowinit @ scalebuildersguild.com
88. oil drums how to by DRW-FJ40@ scalebuildersguild.com
89. Shoe Goo the Easy Way by Vertigo @ scalebuildersguild.com
90. Stop Losing Body Clips! By heyok @ scale builders Guild
91. Syringe Painted Tail Lights By monkeyracing @ scalebuildersguild.com
92. The true scale of scale bodies Tutorial By Copious@ scalebuildersguild.com
93. crow bar by crawlerpaw @ scalebuildersguild.com
94. Bungee Cords – Tutorial By unglewd @ scalebuildersguild.com
95. real scale bungee cords by Copious@ scalebuildersguild.com
96. How to Make Tiny Hinges for Tiny Trucks By pardonmyn00b @scalebuildersguild.com
97. 1/8 scale crowbar by crawlerpaw @ scalebuildersguild.com
