Old 11-20-2015, 03:43 PM
cosworth34677's Avatar
Default Re: should or keep it the same?
Originally Posted by Rimrock View Post
Can understand you frustration..As mentioned in other threads, the first series Magom pumps are just of low quality, some work ok for a while, some works 'so-so' even when new..The new small Magom pump with tank is of higher quality..but it cost some bucks to invest in a new pump, and it's not 100% for sure that pump is the/only problem..
Do you got some fellows nearby that can lend you another pump to test in your machine?
well all my other rc buddy's are car buggy airplane guys, i can try the pump out of my loader but that is working a+ and don't want to f- it up you know.
but my need to bite the bullet and try it out to see if thats the problem. the valve are only about 6 mounths old os i know they are good they where in the loader and worked perfect i'm thinking its more a pump then cyclinder problem in the order
