So each tire has a two piece rim that bolted together to squeeze the bead for a positive lock?
Yes , the two pieces of rim will be bolted to the axle hub. Basically sandwiching the axle hub. And if for some reason if I do have any tire slippage, I have enough material that I could remove more. I also have the rim offset a bit. I will be really surprised if I do have slippage on the rim as they are pretty snugg
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
