Old 12-05-2015, 03:29 PM
Any USB joystick or gamepad can be used for controls.
I'm using a very accurate gamepad from LogiTech. It also has a tiny receiver, which is good when the space is limited:
- Logitech F710
together with the npm joystick module:
Reading the gamepad is done like this:
Code:
var joystick = new (require('joystick'))(0, 3500, 350);
joystick.on('axis', function(event) {
    // Typical Event: { time: 22283520, value: 32636, number: 3, type: 'axis', id: 0 }
    var value = event.value / 32768; // Normalize to the range -1.0 - 0 - 1.0
    if (event.number === 3) { // 3 is left/right on the right pad
        steeringPos = value;
Old 12-05-2015, 04:18 PM
I could have used standard ESCs for the gear motors and controlled them using PWM output from the Raspberry like a normal RC receiver.
But for this project I want:
- Programmable current limiting (to avoid burning the motors)
- Current sense (to output a different engine sound if the load is high)
- Acceleration control
I've beem using the Pololu Qik controller for some previous projects. It's a very good controller, but expensive. But you can actually get a better solution to a fraction of the cost by just combining these two items:
- Monster Motor Shileld for Arduino
- Arduino Leonardo
So for this project, I'm going to try that approach.
I'll program the Arduino to be compatible with the Pololu controller commands. That way the controllers can be swapped if I want to do that later.
The Arduinos connect to the Raspberry via USB and will show up as serial ports on the Raspberry Pi (/dev/ttyUSB0, /dev/ttyUSB1, etc..). The Arduinos are also powered by this same USB cable, so no additional power cable is needed.
To write motor controller commands to the serial port, I'm using the Node.js Serialport module:
To install:
- npm install serialport
Typical code:
Code:
var SerialPort = require("serialport").SerialPort
var serialPort = new SerialPort("/dev/ttyUSB0", {
  baudrate: 9600
serialPort.on("open", function () {
  serialPort.write(controllerCommand);
