Old 12-06-2015, 09:46 AM
Hi, Kevin!
Wow, 50 kg.. that's a heavy machine! :-)
This one is at 30 kg currently, after adding 8 kg lead ballast. It's getting tricky to lift. How do you move yours?
Stein :-)
Old 12-14-2015, 05:31 AM
Just a couple of pictures showing the scale VS a 1/14 Bruder man:
Old 12-14-2015, 06:30 AM
Wiring the electronics:
I ended up buying the motor controllers and the Arduinos on Ebay. The Arduinos ar Nhduinos, a Chinese clone that is a bit cheaper than the original Arduino.
Soldering the Monster motor shield:
I think the motor shield usually ships without the through-hole components soldered. The ones I bought also came without the screw terminals, so I had to use some that I had laying around. I used a quite big one on the battery connector, so that I can add a standard XT60 connector and leads to it:
I cut away the ISP header on the Arduino as it was in the way of the bigger screw terminal and I'm not going to use it anyway:
The monster motor shield then snaps onto the Arduino.
Adding a standard XT60 connector:
This is how the motor controller connects to the Raspberry Pi (USB) and a gear motor:
Adding a 3S LiPo battery and a 5V BEC. The standard servo connector on the BEC incidentally fits exactly onto the 5V header input on the Raspberry PI:
Finally, adding the wireless gamepad and receiver.
The setup isn't that different from a normal RC setup. In this picture, each of the components have the same role as their normal RC counterpart:
- Remote control: Wireless gamepad
- Receiver: Raspberry Pi
- ESC: Monster motor shield
- Battery: Battery
- BEC: BEC
- Motor: Motor
To control six gear motors, I use three motor drivers. To control them all at the same time, I use a self-powered USB hub:
And I made this crude power switch with three outputs:
Old 12-14-2015, 07:12 AM
To program the motor drivers so that they are Pololu Qik compatible (for the commands "GetDeviceId", "SetMotor1Speed" and "SetMotor2Speed"), follow these steps:
1. Connect the USB cable to a PC
2. Download the Arduino programmer: https://www.arduino.cc/en/Main/Software
3. Copy and paste the code below into the programming tool
4. Set the device ID on the second line (any number from 0 to 255, used to identify the controller later) I'm using device IDs 10, 11 and 12 for this build.
5. Click the "Upload" button
Done!
I also added a serial command timeout, which means that the motor driver will stop the motor if it has not received a motor command for one second. Usually the Raspberry Pi will send a motor command 50 times per second, but in the case it loses power or is disconnected for some reason, the motor will stop.
I've not added current sensing or limiting yet.
Code:
/*  Based on the MonsterMoto Shield Example Sketch by: Jim Lindblom */
int deviceId = 10;
#define BRAKEVCC 0
#define CW   1
#define CCW  2
#define BRAKEGND 3
#define CS_THRESHOLD 100
// VNH2SP30 pin definitions
int inApin[2] = {7, 4};  // INA: Clockwise input
int inBpin[2] = {8, 9}; // INB: Counter-clockwise input
int pwmpin[2] = {5, 6}; // PWM input
int cspin[2] = {2, 3}; // CS: Current sense ANALOG input
int enpin[2] = {0, 1}; // EN: Status of switches output (Analog pin)
// Serial state
int inByte = 0;
int command = 0;
unsigned long lastCommandTime = 0;
unsigned long timeoutMillis = 1000;
void setup() {
  setPwmFrequency(5, 8);
  setPwmFrequency(6, 8);
  // Initialize digital pins as outputs
  for (int i=0; i<2; i++)
    pinMode(inApin[i], OUTPUT);
    pinMode(inBpin[i], OUTPUT);
    pinMode(pwmpin[i], OUTPUT);
  // Initialize motors braked
  motorGo(0, BRAKEGND, 0);
  motorGo(1, BRAKEGND, 0);
  // start serial port at 9600 bps:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
void loop() {
  // if we get a valid byte, read analog ins:
  if (Serial.available() > 0) {
    // get incoming byte:
    inByte = Serial.read();
    if (inByte > 127)
      command = inByte;
    else if (command != 0) {
      int speed = inByte * 2; // From 0-127 range to 0-254 range
      int motor = -1;
      int direction = CW;
      switch(command) {
        case 0x88: motor = 0; direction = CW; break;
        case 0x8A: motor = 0; direction = CCW; break;
        case 0x8C: motor = 1; direction = CW; break;
        case 0x8E: motor = 1; direction = CCW; break;
        case 0x83: motor = -1; Serial.write(deviceId); break;
      if (motor != -1) {
        motorGo(motor, direction, speed);
      command = 0;
      lastCommandTime = millis();
  } else {
    if (millis() - lastCommandTime > timeoutMillis) {
  // if ((analogRead(cspin[0]) < CS_THRESHOLD) && (analogRead(cspin[1]) < CS_THRESHOLD))
/* motorGo() will set a motor going in a specific direction
 the motor will continue going in that direction, at that speed
 until told to do otherwise.
 motor: this should be either 0 or 1, will selet which of the two
 motors to be controlled
 direct: Should be between 0 and 3, with the following result
 0: Brake to VCC
 1: Clockwise
 2: CounterClockwise
 3: Brake to GND
 pwm: should be a value between 0 and 255 */
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
  if (motor <= 1)
    if (direct <=4)
      // Set inA[motor]
      if (direct <=1)
        digitalWrite(inApin[motor], HIGH);
      else
        digitalWrite(inApin[motor], LOW);
      // Set inB[motor]
      if ((direct==0)||(direct==2))
        digitalWrite(inBpin[motor], HIGH);
      else
        digitalWrite(inBpin[motor], LOW);
      analogWrite(pwmpin[motor], pwm);
 * Divides a given PWM pin frequency by a divisor.
 * The resulting frequency is equal to the base frequency divided by
 * the given divisor:
 *   - Base frequencies:
 *      o The base frequency for pins 3, 9, 10, and 11 is 31250 Hz.
 *      o The base frequency for pins 5 and 6 is 62500 Hz.
 *   - Divisors:
 *      o The divisors available on pins 5, 6, 9 and 10 are: 1, 8, 64,
 *        256, and 1024.
 *      o The divisors available on pins 3 and 11 are: 1, 8, 32, 64,
 *        128, 256, and 1024.
 * PWM frequencies are tied together in pairs of pins. If one in a
 * pair is changed, the other is also changed to match:
 *   - Pins 5 and 6 are paired on timer0
 *   - Pins 9 and 10 are paired on timer1
 *   - Pins 3 and 11 are paired on timer2
 * Note that this function will have side effects on anything else
 * that uses timers:
 *   - Changes on pins 3, 5, 6, or 11 may cause the delay() and
 *     millis() functions to stop working. Other timing-related
 *     functions may also be affected.
 *   - Changes on pins 9 or 10 will cause the Servo library to function
 *     incorrectly.
 * Thanks to macegr of the Arduino forums for his documentation of the
 * PWM frequency divisors. His post can be viewed at:
 *   http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1235060559/0#4
void setPwmFrequency(int pin, int divisor) {
  byte mode;
  if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
    switch(divisor) {
      case 1: mode = 0x01; break;
      case 8: mode = 0x02; break;
      case 64: mode = 0x03; break;
      case 256: mode = 0x04; break;
      case 1024: mode = 0x05; break;
      default: return;
    if(pin == 5 || pin == 6) {
      TCCR0B = TCCR0B & 0b11111000 | mode;
    } else {
      TCCR1B = TCCR1B & 0b11111000 | mode;
  } else if(pin == 3 || pin == 11) {
    switch(divisor) {
      case 32: mode = 0x03; break;
      case 64: mode = 0x04; break;
      case 128: mode = 0x05; break;
      case 256: mode = 0x06; break;
      case 1024: mode = 0x7; break;
      default: return;
    TCCR2B = TCCR2B & 0b11111000 | mode;
Old 12-14-2015, 05:57 PM
On the Raspberry PI I run the below code. I keep it in a file /home/pi/dev/excavator/control.js
To run this program automatically when the Raspberry Pi gets power applied, just add this one line to /etc/rc.local (just before the "exit 0" line):
Code:
cd /home/pi/dev/excavator/ && sudo /usr/local/bin/node control.js &
The contents of /home/pi/dev/excavator/control.js:
Code:
var fs = require('fs');
// Set a deadzone of +/-0 (no deadzone) (out of +/-32k) and a sensitivty of 100 to reduce signal noise in joystick axis
var joystick = new (require('joystick'))(0, 0, 100);
// State / config
var speeds = {
    leftTrack: { current: 0, wanted: 0, accel: 1 },
    rightTrack: { current: 0, wanted: 0, accel: 1 },
    swing: { current: 0, wanted: 0, accel: 1 },
    boom: { current: 0, wanted: 0, accel: 1 },
    stick: { current: 0, wanted: 0, accel: 1 },
    bucket: { current: 0, wanted: 0, accel: 1 }
// Upate current speeds based on wanted speed from joystick and accelleration limits
var accelInterval = 20;
setInterval(function () {
    for (var propName in speeds) {
        if (speeds.hasOwnProperty(propName)) {
            var speed = speeds[propName];
            var accel = speed.accel * accelInterval / 1000;
            if (Math.abs(speed.current - speed.wanted) < accel) {
                speed.current = speed.wanted;
            } else {
                speed.current += speed.current > speed.wanted ? -accel : accel;
}, accelInterval);
var leftTrackReverse = false;
var rightTrackReverse = false;
// Read the remote control
joystick.on('axis', function (event) {
    // console.log(JSON.stringify(event));
    // Typical event: { time: 1585158, value: 8783, number: 0, type: 'axis', id: 0 }
    var value = event.value / 32768; // Now in the -1 -> 0 -> 1 range
    value = value * Math.abs(value); // Exponential
    switch (event.number) {
        case 0: speeds.swing.wanted = -value; break; // Left stick horizontal / swing
        case 1: speeds.stick.wanted = -value; break; // Left stick vertical / stick
        case 3: speeds.bucket.wanted = -value; break; // Rigth stick horizontal / bucket
        case 4: speeds.boom.wanted = -value; break; // Rigth stick verical / boom
        case 2: speeds.leftTrack.wanted = (leftTrackReverse ? -1 : 1) * ((value + 1) / 2); break;
        case 5: speeds.rightTrack.wanted = (rightTrackReverse ? -1 : 1) * ((value + 1) / 2); break;
joystick.on('button', function (event) {
    // Typical event: { time: 1607722, value: 0, number: 0, type: 'button', id: 0 }
    if (event.number === 4) { // Left top shoulder
        leftTrackReverse = event.value !== 0;
    if (event.number === 5) { // Rigt top shoulder
        rightTrackReverse = event.value !== 0;
// The motor controllers
var SerialPort = require("serialport").SerialPort;
function startMotorControllerOn(devicePath) {
    var serialPort = new SerialPort(devicePath, { baudrate: 9600 });
    serialPort.on('open', function () {
        serialPort.on('data', function (data) {
            var deviceId = data[0];
            console.log('Got device id: ' + deviceId + ' from ' + devicePath);
            clearInterval(idInterval);
                var motor0Speed = 0;
                var motor1Speed = 0;
                switch (deviceId) {
                    case 10: motor0Speed = speeds.leftTrack.current; motor1Speed = speeds.rightTrack.current; break;
                    case 11: motor0Speed = speeds.swing.current; motor1Speed = speeds.boom.current; break;
                    case 12: motor0Speed = speeds.stick.current; motor1Speed = speeds.bucket.current; break;
                var cmd = motor0Speed >= 0 ? 0x88 : 0x8A;
                serialPort.write([cmd, Math.abs(motor0Speed) * 127]);
                cmd = motor1Speed >= 0 ? 0x8C : 0x8E;
                serialPort.write([cmd, Math.abs(motor1Speed) * 127]);
                // console.log(JSON.stringify({ d: deviceId, a: motor0Speed, b: motor1Speed}));
            }, 50);
        var idInterval = setInterval(function () {
            console.log('Sending request for device id... to ' + devicePath);
            serialPort.write([0x83, 0]);
            console.log('Sent request for device id... to ' + devicePath);
        }, 1000);
startMotorControllerOn('/dev/ttyUSB0');
startMotorControllerOn('/dev/ttyUSB1');
startMotorControllerOn('/dev/ttyUSB2');
Old 12-14-2015, 06:22 PM
The first test drive of the full working skeleton!
https://youtu.be/ueaT-cYe8B4
The lead ballast is not mounted in this video. And as as you can see in the video, it really needs to be added. Too little weight in the back. :-)
I'm quite happy with the handling. It is very precise and very strong. Also, it's dead quiet except for the swing motor. I don't know why that motor is making so much noise. I have ordered another one just to make sure it isn't just that one particular motor.
Old 12-15-2015, 10:52 AM
Very nice job! It's nice to see something different although the control boards are way over my head.lol
On a different note. How did you post your video(embed) like that on this site? I didn't think we could do that here. I'm glad we can!
Keep up the great work!
Reg
