![]() ![]() ![]() ![]() ![]() ![]() I know things look pretty chunky, once all the arts are fitted and I know they will work I will be trimming and adding detail. I've been putting off mounting the differential pinion shaft but decided better do it. The bearing protruded a bit from axle housing so I had a lot of set up time with the 4 jaw chuck. That piece is also connecting outer axles together and a frame will mount to it. I also wanted to make a bit of play for bearings. Would rather add some shims to get correct mesh of gears than have to mill some more out. Not fun on set up to do that. ![]()
Lookin good!
Looks real good you will have a hard time breaking that. Ed
Currently Active Users Viewing This Thread: 28 (0 members and 28 guests) | |
