Old 12-15-2015, 10:54 PM
Default Re: Magom D11 hyd ram ratings?
Update: Here's the specs direct from Magon;
Customer message: I ask about Cylinders kits for the Bruder D11 - MG-50100401.
(1) Can you tell me the diameter of the kit cylinders eg:, they all look same dia/size? Is it 12mm? 18mm? 22mm?
(2). Can you tell me the kg lift-capacity of the blade lift and ripper cylinders please.
Thank you
Reply: Thanks for contact us and be interested in our products. The cylinders for the D11 are 12 mm bore.
They can handle up to 25 bars of pressure. The lifting capacity is difficult to say, it depends on the angle, pump pressure, flow, etc.
Any doubts, questions, please do not hesitate to contact us again,
Best regards
So it appears the blade lift rams and the 4 x ripper barrel rams are same dia?
