Old 12-22-2015, 10:09 PM
Default Re: LilGiantsConstrCo
About 12yrs in the making Brandon.
My china gear motors finally showed up today, got one that is 55rpm & the other is 160rpm. Before taking apart the V1 tunnel grinder I checked the rpm with a 12v NiMH, it's 200rpm... starting with the 160 rpm g/m, a few more hrs fab work to do yet.
Made another vid this morning placing the gopro on the cab of the B50... the 30% faster pump didn't make a dramatic difference in speed, but I do notice it's a bit faster. What's most interesting is my run time on a 5amp pack dropped about 20%, 45-50min down to 35-40min. And also, when the pump slows down to its idle speed there's this sorta chirping sound, kinda like how a muffled diesel sounds on fast idle, it doesn't make that sound when motor/pump is running full speed & the previous pump never did it at all.
https://www.youtube.com/watch?v=6n3p95e-rFo
Old 12-23-2015, 05:24 AM
Rimrock Rimrock is offline
Quite an impressive open pit operation you got going there) I would think there are not many of these machines around seeing that number of hours on the meter ...Vario/Fumotec might should hire you as a test driver, if they don't already do
I notice that both Vario/Fumotec and Premacon chose pump motors running at 8000-9000 rpm no load, 600-900KV, relative high imo. I've not seen a Vario 850 running live, but seeing your videos I hear the pump motor kind of struggle when running against the PRV. Have you turned up the PRV setting, or is it the factory setting, and the chosen motor might be a bit under-powered?
I've never been such an fan of these 'high rev' pump setups, and working at putting together my own 12V setup with a Jung HR7/4003 and a 360KV, with motor running at around 4000 rpm no load, pump 3000 rpm, which will hopefully reduce the noise, wear of bearings and transmission parts (belt) a bit compared to the german setups. Time will show)
