The heavy duty front coupling
![]() ![]() ![]() ![]() Support bar for the push/pull rods gets bolted on. ![]() ![]() The push/pull rods that will attach to the chassis ![]() The bits in the upper left corner are not used here. They are to attach the coupling to the frame of other models. ![]() The M2x20 bolts get installed throught the previously drilled holes and the spacers put on. ![]() Bumper ready to be attached to the frame ![]() Bumper attached and screw needs be bolted through the black grill and chassis. This screw serves to hold the spring to lock the front of the cabin and also prevents the unlikely event of the bumper being pulled of the frame. ![]() Screw bolted on and spring installed. Arrow indicates where the push/pull rod from the heavy duty coupling will attach. ![]() ![]() ![]()
Tags |
man tgx xl, scaleart, trailer |
