Old 12-28-2015, 12:45 AM
Default Re: KW c500 double set back tandem tandem 8X8 help
I remember you had posted a question in the tech forum about correcting winch creep from your continuous rotation servos... I think I found a solution for you, if you haven't already solved it; the product is made in Burnaby, BC.
http://www.freewebstore.org/HeyOK-Pe...2_8013975.aspx
Old 12-28-2015, 07:22 PM
Jakyat Jakyat is offline
Jakyat is on a distinguished road
That is an interesting link. I have checked into it and I am placing an order. I also found in there site, external bec that scalers use for steering servos. They are plug and play, and they would allow me to draw my power for both rotational servos for the winch from a separate power source w/o drawing through my esc. Thank you for the great link.
Old 01-04-2016, 08:41 PM
You're welcome... but kudos goes to Kalle (Azonic) for the find, as this is where he sourced the timed esc for my quick coupler on track hoe from, I've been having trouble with it lately & either need this guy to reprogram it for me or supply me with a new one.
Old 01-21-2017, 05:48 PM
Good day to all!
As you all can see, it has been a year since I have posted anything on here. I have had my project put away. I have recently got back to work on it. All I really have left is all the detail work 😖.
File Type: jpg IMG_3977.jpg (157 Bytes, 125 views)
File Type: jpg IMG_4095.jpg (157 Bytes, 124 views)
File Type: jpg IMG_3976.jpg (157 Bytes, 124 views)
Old 01-21-2017, 05:57 PM
I am now onto the lighting and I am turning to you guys for help. By the time its all said and done, there should be close to 30 leds running on 4 different channels. Im using 3 volt leds. I have purchased some receiver activated switches and will be using the x-plus module withmy dx 18 tx. Rather than trying to figure out which resistors i will need, I would like to supply the x-plus with its own power source to effectively power the leds without resistors. Doing it this way, I should be able to turn lights on and off with the toggle switches on my tx.
My problem is, I don't know how much power i need to feed the expansion module. Im looking for feedback from you guys. I don't have enough room to install a mfu.
Old 01-21-2017, 09:19 PM
Old 12-28-2015, 09:39 PM
Bo Wallen's Avatar
Thumbs up Re: KW c500 double set back tandem tandem 8X8 help
Good find Joe Going to order
Old 12-28-2015, 10:16 PM
I wonder if they would run my truck dump beds?
Sorry for getting your thread off topic...
Old 12-29-2015, 12:19 AM
lol!! that's no problem at all Reg. As you can see, I haven't been on in a long time. As a matter of fact, I think its kinda ironic and funny, that I just happened to pop on the same day that Joe had left his comment.
Old 01-22-2017, 02:53 AM
Talking Re: KW c500 double set back tandem tandem 8X8 help
Joe, if you get this....and anyone else that mayb be interested, I have finally tried this mofset controller. Wow. 1st, id like to say ; Amazing service!! I didn't feel comfortable doing this mod myself, so I disassembled my winch module and sent both my winch drive servos out to Burnaby. Mr. Jackson with Heyok did the mod for me and l had my servos back within 8 days from the time I dropped them in the mailbox. He installed his 4amp switch into each servo. This modification allows you to draw power directly from the battery bypassing the esc. The first time i tried my winch, the hook snagged in my frame rail and broke my winchline which is rated for 80lbs��!!! unbelievable!! It always pulled hard but wow. The problem i was having was no brake in neautral position. (Winch creep). It still creeps a bit at about 20 lbs, which is fine. I can live with that.
This is my winch module(a year ago). You can see the two continuous servos mounted under the drum, both with 1" servo gears which drive the gears on either side of the drumm. All of this hardware came from servocity.
Old 01-22-2017, 03:02 AM
Joe, if you get this....and anyone else that mayb be interested, I have finally tried this mofset controller. Wow. 1st, id like to say ; Amazing service!! I didn't feel comfortable doing this mod myself, so I disassembled my winch module and sent both my winch drive servos out to Burnaby. Mr. Jackson with Heyok did the mod for me and l had my servos back within 8 days from the time I dropped them in the mailbox. He installed his 4amp switch into each servo. This modification allows you to draw power directly from the battery bypassing the esc. The first time i tried my winch, the hook snagged in my frame rail and broke my winchline which is rated for 80lbs😮!!! unbelievable!! It always pulled hard but wow. The problem i was having was no brake in neautral position. (Winch creep). It still creeps a bit at about 20 lbs, which is fine. I can live with that.
Old 01-22-2017, 09:18 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Looks good! Have you got any different contact info about the mod. The link you give is dead for me.
Thanks.
LYNN
Old 01-22-2017, 11:39 AM
Thanks.
Try this. https://www.freewebstore.org/HeyOK-Performance
If that doesn't work, i just google search "heyok" and it will take you directly to his webstore.
