Old 12-28-2015, 12:08 PM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
Hi Folks,
long time passed by and for some reasons i couldn't work real much on the project. Hopefully this will change in the next weeks. Anyway, a little work was done. First I made some drawings for more lasered and waterjet cut pieces for doing the pipework on the boom. Parts are made from steel, brass and polyamid/ nylon.
First some parts for keeping the bolts in place. The bolts with the rings are screwed together. The main bolt takes a endcap and those parts clamps the ring - just simple. The locking assembly is screwed with m1.6 screws to the frame. For setting the thread at the right place I used some drilling jigs.
Old 12-28-2015, 12:17 PM
Next was some work on the motor housing. Drawings were made for lasercutting and bending. For welding I used a big chunk of aluminum to draw out the heat. After welding I did some filing work. The whole cover is screwed together, I won't use hinges for single opening the lids. In case I take of the whole mounting.
Old 12-28-2015, 01:17 PM
JAMMER JAMMER is offline
Hello Markus K great job on the tracks I really like them so I will take 600 hundred links how soon can you have them done? All kidding aside you have done a great job on building this excavator. Ed
