Old 12-28-2015, 10:00 PM
TRUCKMAKER's Avatar
Default Re: King Hauler driveshaft length?
Check out this thread for an inexpensive way of making your own shafts.
http://www.rctruckandconstruction.co...read.php?t=708
You can also adjust the drive cups on the axle and transmission so there is very little fore/aft play in the shaft when all tires are flat on the bench, then see what you get when you flex the suspension and readjust accordingly.
Old 12-28-2015, 10:02 PM
avel avel is offline
yeah i've already read that thread a couple days ago. Pretty cool.
Also good idea with adjusting the cups, I hadn't thought of that.
I mainly want to buy something so when I get hometime I can pop it in, and go play
Youtube username iamaman27
