Old 01-23-2016, 09:02 AM
thetractorfan thetractorfan is offline
thetractorfan is on a distinguished road
Default Re: Excavator problems
Originally Posted by Cornbread View Post
Im new on here lurking around reading about Excavators. I was that is was, gonna buy one. But I see ton's and ton's of problems. It seems that the problems are in the valve block, of these excavators with pressure not being directed to where it needs to go inside the little Valve blocks. And being servo run wow that is a whole can of Noodles. What I see should be done is, someone needs to do is Machine a clear acrylic valve block to see what the **** is going on inside of it, Just my two cents..
Corny...
What I would do is buy a premacon, damitz or fumotech excavator. Here's why:
. Premacon, damitz or fumotech excavators are much stronger and more reliable than some of the other brands on the market.
. They can come with auxiliary hydraulic valves and quick couplers.
. They never use thin metals that are weak and always use high grade metals.
. They require fewer maintenance.
. Very good cutomer service.
Now the competitors equipment:
. No auxiliary valve or hydraulic quick coupler option.
. Made from low grade aluminum.
. Hours of maintenance.
. Who knows how many spare parts and how long they will supply you with them. also will they tell you when you need to change the hydraulic oil?
