#1341
Lol!!! It's been a while since I last actually saw one in the daylight, but yes Pennsylvania has beavers, and Amish too, but I don't know about Amish beavers. Maybe this weekend mark, you can ask some of our planers (Amish) if they breed any beavers or if they make too much of a mess with damming up the streams for more fruitful harvests. I don't think pa allows trapping them anymore. Or maybe you have to get a fur bearers liciens if you trap them. It's been a while since I've been on any hunting trips
#1342
Cooper , when you got the banebot gearbox , did you get it with the steel ring gear or the aluminum 1 ? I saw they come standard with the aluminum . To get the steel you have to order special .
#1343
After two attempts, the third wheel was correct. The two on left are scrap bin parts, the two on right are final wheels.
![]() ![]() ![]() ![]() I didn't install the races yet as they are a press fit and still haven't finalized the shocks or steering knuckles. Dust seal will be in inner axle side and a hub cap will cover the outward side.
#1344
Question for you guys, I'm working on front suspension,,, how I want to set it up is similar to 1:1. If I use hard brass for the suspension cylinder shaft and have bronze bushings as the cylinder, will those two wear pretty well? I need the up and down of the suspension as well as the turning for steering on same vertical shaft. Shaft is 7/8 diameter and all but about 1/2" will be in touch with bushings. 1/2" in middle for travel. Bushings are 3/4"-7/8?? Tall, so most of the shaft will be securely held. I had thought of using orings as seals and guides but after thing about it I think the orings would be shot very quickly as she is a heavyweight. I even thought about having a grease fitting on top, would be hidden by top of cylinder so that is also a way to keep things lubed and moving. Sounds like overkill but this area is going to take a pounding. (And I tend to over engineer/complicate things )
#1345
I'd use stainless shaft and press oillite bushings into the cylinder .
#1346
Wow, this thing is going to be a beast indeed Cooper. Need another vid of the 11 pushing, its been a while.
Joe |
#1347
It's an old one but some good pushing. Ground is frozen right now, but may be able to push some snow this weekend ![]() http://youtu.be/S_BeiNuCuZY
#1348
Thanks for the radio info jammer,,
Hey guys, I know a few of you have sent me pics of the 785d or b machines, I believe my wife tossed my photo album (long story short) ,,,, but do any of you have frame pics, particularly of front suspension towers? Working on them next and the steering. Thanks, I'll make hard copies this time!!!
#1349
how come your wife tosses all your stuff in the trash??
#1350
Ohhhhh,,, where to begin,,,, lol!!! We both have iPhones, when she got hers a year or so after I did, she didn't want to get her own Apple ID and I didn't know what she was doing. She used my ID to set up her phone. Now it is like I have two phones, everything syncs with everything. No big deal but she deletes things "she" doesn't think are important. (So do I,
![]() Oh the tangled web we weave,,,,, all for love. Yeah, not!!! Lol!!!
#1351
Oh and one thing to add, when she contacts me by phone, everything will be fine because she will not be able to call me till she gets her own ID and phone set up!!! At least that's how I envision it
![]() ![]() ![]() Now after a couple days and no contact,,, I may not go back home ![]()
#1352
ouch
#1353
That's why I'm building and not buying! Lol!! Wife would rather me build, keeps me occupied in garage when I'm home!!! Steve I did get some stainless, 416, and the correct steel is easy to use!! The one pic has the mock up in brass but I have remade in stainless.
![]() ![]() ![]() Last pic is the bolts holding the suspension towers. Everything will be milled down once proven to work. And the part holding towers is one piece from bottom cross member through frame rails. All integrates together for strength and rigidity, (I think ![]()
#1354
I know you said it's a mock up pic. The way you have the bearings is the opposite of how the real machines are. Bearing tapers should face inward.The cups are in wheel hub opposing each other.
#1355
This thing is gonna be 200 pounds with a load of dirt. You better start building brake drums...
Carry on... ![]() |
#1356
Good spy Mario, I just double checked and I do have them mounted correct, just not in the pic. I left some wiggle room on being able to tighten them down with shims or use thread lock on bolt holding them in. It's a m8 bolt holding them on. And a hub cap , so to speak, will be hiding them, and keeping grease in along with seal on inner side.
I also just double checked the steering, 36 degree angle and a 1:14 scale turning radius of 93". She is big!!!
#1357
#1358
Yeah!! That's what I'm afraid of!! Hopefully I can mill off a lot of material when she is built!!!
#1359
Looks good Coop . I assume your putting a spring in the top with a cap along with some type of keeper .
I think a dewalt V24 will werk great for that kinda weight ![]()
#1360
Yes Steve, hopefully tonight I can figure out the spring and cap. I'm using a external snap ring for downward retention. And spring for suspension. I'm thinking of having the spring inside shaft so cap will not be so tall. Have to look at some more pics of 1:1.
