Construction Equipment Tech Hydraulics, Electronics, General Engineering, ect in constr equip |
if the oil is hot, change the oil. if it is dark, contaminants may be clogging up the system, making pressure causing heat. a proper sized pc radiator should do, you don`t want the bearings in your pump to burn out.
