Old 02-01-2016, 09:00 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
Actually I should invest in decent airbrush equipment. it's available here in Malaysia, but the supplies are rather hard to get. Because paint and thinner are "dangerous" cargo, they do not allow it on planes. So comes in on the slow boat and they never really have stock. Of course I don't order big enough supplies to make it worth their time.
The zinc primer is supposed to be self etching ... will see if it is true. According to their info it should be neutral with other paints and provide excellent adherence. Will try and see.
I also got regular grey acrylic primer in case the zinc based one doesn't work out. Whatever, it has to be better than the locally produced stuff.
Well living on a tropical island does have certain drawbacks ... there are days I wished I was back in Europe, specially if you have to wait weeks for some simple stuff.
Old 02-04-2016, 10:22 PM
Rakthi's Avatar
Another short update.
Since I will use the rear leaf suspension, I re-installed the heavy hauler rear end again. I wanted to install a coupling too. Not the Rockinger variety but a simple one which is also available from ScaleART.
Will need different nuts and bolts to hold it on, this would look a bit odd even after painting.
Another thing, because the heavy hauler attachment is set deeper in, the pin can not be inserted or taken out. It bumps against the top part. I will have to rummage through my junk pile and see if I have something of suitable thickness to bring the part out enough.
Tags
man tgx xl, scaleart, trailer
