Old 02-13-2016, 01:50 AM
JonBailey JonBailey is offline
JonBailey is on a distinguished road
Question What is a good method for applying decals/stickers?
For instance, the Tamiya flatbed trailer comes with a sheet of stickers.
I would like to be able to put on my stickers neatly without creases or air bubbles. The stickers also have to be positioned in precise locations on the body without being cock-eyed.
Kenworth, It's Gotta B the Big Kay Double-Yoo 4 Me!
Old 02-13-2016, 02:14 AM
Default Re: What is a good method for applying decals/stickers?
This is where water-slide decals have an advantage. They can be moved on the surface slightly, air bubbles can be gently pressed out before they dry and set.
Old 02-13-2016, 02:53 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
The tamiya stickers are just as good as vinyl ones and can be applied the same way if you google how to apply stickers and vinyl you will see how to apply them...............
And this topic was taked about a few weeks ago.............
Also another advantage of stickers is they dont yellow with age like some decals do............
Love my Kenworths
Old 02-13-2016, 02:55 AM
Cossett's Avatar
On Leave
Love my Kenworths
Old 02-13-2016, 06:26 AM
Already tried Google. No dice. Only info on water-slide decals.
Old 02-13-2016, 08:24 AM
bigford's Avatar
bigford bigford is offline
usev windex as the water under your sticker and a credit card start in the middle and work
out to the sides soak up extra windex as you go.
that is from a 0.06 second search on google how to apply vinyl wraps
Old 02-13-2016, 10:13 AM
bigford's Avatar
Old 02-13-2016, 11:41 AM
mcl fabrication mcl fabrication is offline
mcl fabrication is on a distinguished road
There are plenty of videos on you tube about installing and removing stickers of all sorts. What you are looking for is a easy answers, but there are none. Even if you are told exactly what to do, you must still have hands on experience.
The bottom line is to try all that you have learned again and again until you get it right. This hobby is no different than learning to ride a bicycle.
Old 02-13-2016, 05:45 PM
Prop Shaft's Avatar
Apparently theres no need for this forum with google around....
At any rate, I can share a tip I learned years ago about getting decals positioned. After cutting out your decal, (if not precut). I like to fold back or cut off a small section of it. For instance if the decal is rectangular and say an inch long, Ill cut about a quarter inch off one side, position the decal where I want it, being carefull not to let the sticky part touch the model. When I happy with the position, Ill push down the exposed part of the sticker, then lift up the other side and peel off the rest of the backing. Then work the sticker down with your finger or credit card or whatever, away from the portion you first stuck down.
Ive also used windex to apply vinyl decals with great results. But not on toy trucks. Ive used this method on 1:1 vehicles with fantastic and long lasting results. Be VERY carefull using windex on model paints. I know windex will absolutely destroy Tamiya acrylic paint. **** I use it to clean my airbrush. GL
Old 02-13-2016, 05:47 PM
Prop Shaft's Avatar
Really? The word H e l l gets censored here....
Old 02-13-2016, 05:50 PM
bigford's Avatar
yup this is a family friendly forum.
because I know a lot of kids that can afford $7000.toys
