Old 02-17-2016, 07:57 PM
Default Re: LR634 is HERE!!!!! Tracked loader
That hyd tubing is probably the same stuff Fumotec & Vario use, definitely high pressure line, but it don't like to bend tight radii... if you do need to make a tight bend though, careful use of a hot air gun works well.
Also, the use of this type of hyd line, did you get all new fittings as well? I don't think this type of hyd line will work with Leimbach's barbed fitting & press-on collar.
