Drill a hole in roller & fill it with sand? ...that might impede rolling, water?
What's its guesstimate weight before mods? Any way to implement a cell phone vibrator?
Or motor and weights from a Playstation controller or something, might be stronger..
Or you could get a motor, add a weight on one side to throw it off balance and you have a vibrating motor.
Water could work, but it may rust the metal and leaks could turn the soil under the machine into mud. Combine this with the weight and you are stuck again. And the grease may not function properly if water hits it. |
I didn't weigh them beforehand but I doubt they were two pounds. They will be a little heavier than that when finished. I finished all of the servo and axle mounts today and started making the rear wheels. These little buggers have a rigid body on the rear now with all of the aluminum bolted in. Should be strong little models even though the shell is plastic. I bought some vibrating motors for them months ago. They are a bit big but I will see what I can do...
If you went the water filled route, most small tractors with water filled tires use windshield washer fluid instead of straight water. It's really not worth the rest of the opitons unless you have a friend who has some left over 'rimguard' or something.
http://www.michelinag.com/Learning-a...llasting-tires http://www.orangetractortalks.com/20...-tire-ballast/ If you think water or sand would weigh too much, maybe look into airsoft BBs. |
