Old 12-24-2010, 02:04 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: cnc ?
Hi Steve,
The lathe I run at my primary job has 3d capable graphics as it has live tooling in the turret- mill heads in some of the tool pockets. The older lathes just have 2d graphics. You really only do things on a lathe in 2d. X and Z points are all that are needed.
Hope this helps you decide what to get!
Lynn
ps- You could make your wheels in 2 setups on the lathe I run now!! Your hubs would only be 1 setup. Unless my figuring is wrong you could make your wheels out of aluminum in about 5 minutes per wheel or maybe a little faster. This will let you know what your out source provider is trying to make per hour!
Old 12-24-2010, 02:19 PM
Default Re: cnc ?
Lynn , yea I pretty much figured that he got to keep his guys working You just answered another ? live tool on the turret which is the intention , do the whole process on the lathe . I still would be getting a mill later to make other products . I figured a lot of you cnc guys would be a great help in me overcoming this cnc phobia I have
IHSteve
Old 12-24-2010, 02:26 PM
tc1cat's Avatar
Super Moderator
Default Re: cnc ?
Don't know what your bank account is like but the machines I run are well into the 5 figure catagory. Then you have to buy the tooling! Some of the angled milling tool holder are over $3000 each! It is very easy to spend more on tooling than what you did for the machine.
Lynn
Old 12-24-2010, 02:42 PM
Default Re: cnc ?
Lynn , I'm thinking (I know ) it'll take me awhile to get to that point I'm at least hopping to speed up the process I have now . making the actual wheel is a walk in the park but when it comes to the hubs , is what slows me down to get the accuracy for the bearing and hex seats and keeping consistent
IHSteve
Old 02-17-2011, 11:56 AM
Default Re: cnc ?
dumb ? maybe My mill takes NST # 40 tool holders . Now , is it possible to use a cat 40 if I lengthen the draw bar ? I'm looking around at various places and it's hard to find the NST #40 . now I didn't go where I usually find stuff yet , they got a bunch of used tool holders . I do not see an issue with finding them for the larger end mills but for the mini end mill with 1/8" and 3/16" shank . Hmmm , thinking as I type maybe I'll just make an adapter to go in the larger end mill holder . BTW Pugs , thanks for that link you sent me good deals on end mills .
Steve
