Old 03-02-2016, 11:50 PM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
More work done on the frame....servo tray is finished and installed
[IMG]
[IMG]
[IMG]
The 1/4" shaft under the servo tray will be the pivot point of the spring loaded belt tensioner for the small vbelt pump drive. Throwing around the idea of adding a sevo to the tensioner shaft and being able to disengage the belt, the motor would continue to turn but the pump would stop, decreasing the amp draw and adding a little bit of battery time....really trying to avoid using an ESC on the pump motor if possible....just a thought
[IMG]
[IMG]
[IMG]
Thanks for looking....
