Old 03-03-2016, 08:57 PM
Snowman3725
Guest
Posts: n/a
Default Re: AWD, worth it or not?
Originally Posted by Claus View Post
If you want away from those bolts holding the case together you can buy an aluminum case that replaces the plastic one. I have one of these, there is no bolts in it at all. $65.00 on the ole eBay.
Perfect! I'll space the trans up 3/4 of an inch and use the case. That will give me plenty of room for the shaft going to the front to clear under the trans. Anyone ever used the rc4wd bullet 3 speed transfer case? I'm curious about the gearing. It says 1st is 1:1 and second is 1:9:1 gear reduced and 3rd is 2wd 1:1 Why would 2nd be lower than first?
Old 03-03-2016, 09:36 PM
Because it is not a true 3 speed it is a high low 4wd and high 2wd. Its a diconnect for when 4wd is not needed.
