Old 03-04-2016, 05:34 PM
Default Re: Metso Lokotrack LT120, Jaw Crusher.
Well, I got a bit more done to the crusher. I got a new more powerful motor for the feeder, works much better now.
Also got most of the conveyor done, a few more pieces to do but Im almost there.
Here are a few pics.
Old 03-05-2016, 10:38 AM
Bo Wallen's Avatar
Thumbs up Re: Metso Lokotrack LT120, Jaw Crusher.
Really Good work going on here...........I'm following you're build closely .......Heja Sverige
Old 03-05-2016, 03:31 PM
Tackar!
Träffat kärleken i Usa?
Old 03-05-2016, 03:34 PM
Here are some more progress from today...
Old 03-05-2016, 03:44 PM
Bo Wallen's Avatar
Originally Posted by Azonic View Post
Tackar!
yup 10 year now
Old 06-12-2016, 12:40 PM
Any more progress on this outstanding build?
Old 06-12-2016, 05:31 PM
Not really, I have done a test run, but I forgot that I just had spot welded the fixed crush plate so it came loose and that was the end of that test!
I did re-weld it the other day though, so now it shouldn't break loose.
One more thing I have noticed is that the crush plates should go into each other if you would lay them together, as the sit in the crusher now, the tops of the pattern lines up with each other, guess it would crush better the other way.
That's about it, it's summer now and I don't spend much time in this hobby this time of the year, more of a "get through the winter" kinda hobby.
Old 06-13-2016, 07:58 AM
I noticed too that the plates need to be offset . It would definitely take less effort to crack a rock in half pressing it over a sharp point evenly rather than pinching it like wire cutters work.
I am working on some crushing equipment as well, but a slightly larger setup using existing laboratory crushers.
