I looked at a bunch of pictures, and made some guesses, and started to cobble up a dragline bucket out of stuff i had on hand so I could play around with the mechanics of it. Brass sheet thats too thin, hollow tube, and some electronics solder...
BUT I think it's acting about like it should and once the rigging is done in chain i might be onto something. (I started before i saw the patent drawings to copy, but it should work on soft loose stuff.) ![]() Prototypes aren't pretty. ![]() Also started setting up for hoist and crowd drum servo mounts, and working toward getting steering servo in. Last edited by frizzen; 07-19-2017 at 03:57 AM. Reason: photobutt |
next up, i took some 0.063" aluminum 2024 t3, and graph paper. I think this is a good start on side panels for a boom extension. That's the longest i could fit on 8.5x11 paper, i can post up template if anyone wants. Planning to make an even longer mid-boom just because i've got some longer aluminum. This one will put my boom reach at 32" once complete.
![]() Then some brass stock turned into a windshield wiper and side mirror. I really should try to get back to making drums soon so i can get back to servo mounts... Last edited by frizzen; 07-19-2017 at 03:59 AM. Reason: photobutt |
I've been looking at servo accessories, trying to to come up with the easy way to do this instead of needing a lathe.
On servocity I've stumbled across 'servo shaft hubs' which are a splined 0.5" shaft and one end of the winch drum. Or they have 'servo shafts' that are just a shaft in 0.5 or 0.375 with the spline drive. I can probably fab up the other side plate, tap/die, and with a little locktite. Hs645 uses their 'C1' 24t splines and i can find 32pitch and 48pitch gears to fit it made of Acetyl and brass. But i haven't figured out what the slew gear donor should be to make it all work.. i also learned the vex gears are 24 pitch. Last edited by frizzen; 08-27-2016 at 04:27 AM. |
What about a small gear motor with a drum on it, like this one?
- http://www.ebay.com/itm/262553977068 And control it with an ESC. Best regards, Stein :-) |
As an alternative, for the slew and pinon gears, maybe you could use something like this:
- Pinion: http://www.ebay.com/itm/151889646562 - Slew: http://www.ebay.com/itm/161891095040 You can see they have almost all types of bores, mods and number of teeth: - http://www.ebay.com/sch/m.html?_odkw...+gear&_sacat=0 If you select a 4mm bore, then you can use a gear motor like this one: - http://www.ebay.com/itm/381486411254 60 RPM / (66 teeth / 12 teeth) = 60rpm / 5.5 = 11 RPM 11 RPM for the swing would be quite ok, I think. Best regards, Stein :-) |
Frizz,
I'll turn the drums for you if you know what you want/need. Mine are pretty simple. You want them as large in diameter as you can fit nested next to each other. And for width I just wanted the drum to be centered in the "window". Now, for the tricky part. I don't like the way I attached mine to the servo, but I have had no problems with them so far. I drilled and taped the servo spline screw hole to something larger, probably 2-56 or 4-40 I don't recall which. Then a matching stud installed in the drive end of each drum and a pin in the off end of the drum which is held by the support channel at the other end. Ideally you would want the drive end to be a spline to match the servo but that is way past my machine skills and tooling. Jim |
SteinHDan, that would work too. I was just planning on running the gearmotor/esc combo units like i'd seen on other cable machines like built by thestuff, smallhaul, rvjimd
Truckmaker, yeah you're right what can i say... i suck at building and having time/money. I know the longer boom will impart a lot more moment on the machine, i just wanted to see how things change around, and more reach looks really cool. I'm also not above running lead ballast if it needs it. jim, i greatly appriceate that. I was thinking something maybe built off one of these: https://www.servocity.com/standard-hub-horns Thinking i can have a protrusion to index to the .500 hole and a flange to bolt on the near-side. i wasn't sure if it's worth it to have far-side support on the drums? I need to break out calipers and think and mock up a bit before i'd be able to do a dimentional sketch for your consideration. Or depending on the alloy you have, i might be able to just order a spare gearset and just broach the splines into a much simpler drum instead of getting that crazy. |
