Old 03-10-2016, 11:29 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: ScaleART - Assembling a MAN TGX/XL 6x6 tractor & Trailer
So my second try did work out. Bracket finished. Still needs some filing and sanding to take the sharp edges off.
Trial fit worked too.
Still needs a bit of adjusting and maybe try with the bracket on the outside.
Fits with the front fender too. The bottom air tank needs some mm filed off to accommodate the curve in the front fender.
Old 03-11-2016, 05:06 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Can you raise the tanks to allow the bottom tank to fit without mods? Looks like there is a little space to raise the mounting plate. Noticed you made multiple mounting holes in the plates for adjusting.
LYNN
Tags
man tgx xl, scaleart, trailer
