Old 03-17-2016, 07:08 PM
Cooper's Avatar
Cooper Cooper is offline
Whoohooo!!! That's a big box!!!!
Finally got around to using the tig welder on steel. Wow a lot easier than aluminum!!! I guess I'm backwards because I learned how to tig weld aluminum first then steel. Definitely gonna be a very useful tool for building with sheet metal. These were the first parts I got to tig weld, mild steel onto stainless shafts.
This is the start of the new garage/shop/ super-mancave!!!!
Found a use for the one side tank, housing the prv and gauge. Not needing to access it too often. All the holes in cover will have screws but the whole box slips off with only a couple screws.
And started running hydro lines. Working on hooking up electronics to get a first test run in tranny and hydro cylinders.
