Old 03-20-2016, 03:37 AM
Hi RobotArms24!
The infill is set in the printer settings (not in the model) and it's typically only used for FFM-machines (the typical home desktop 3D printers). Shapeways will always make a solid model, I believe.
I usually print with something called "fast honeycomb". There are lots of alternatives, but I feel that fast honeycomb is a good combination of strength, speed, weight and also the zig-zagging gives less pull on the edges and less warping of ABS prints.
I use a software called Simplify3D. They have a lot of good information on their web site. This is a video on infill:
- https://www.youtube.com/watch?v=BMWTK2ZgJCM
And they also have and this very helpful 3D-printing troubleshooter:
- https://www.simplify3d.com/support/p...oubleshooting/
I don't know exactly the strength of different infill percentages, but to the hand it feels linear, i.e. 20% feels twice as strong as 10%.
Best regards,
Stein :-)
Old 03-21-2016, 05:16 PM
Starting to paint the metal parts on the boom, stick and bucket linkage. Need a couple more layers on the stick parts.
The paint color is the closest match I could find to the ABS filament color in the previous step. It's this one:
- Dupli-Color 577789 AC 3-0600
Sanded (120 sand paper) and primed with aluminum etch primer first.
It's a shame, really, to cover shiny metal in this way ;-)
Old 04-01-2016, 06:59 PM
Mounted the counterweight to the base plate. After testing with 4, 6 and 8 kg ballast, it seemed 6 kg (13 lbs) gives the best balance.
I bought 2 kg (4lbs) lead plates from a local scuba-diving shop:
- http://dykk.no/main.aspx?page=article&artno=MTDA-1
I don't like exposed lead because of the health hazards, so I covered it in liquid plastic and added a shrink wrap tube on top of that. Probably overkill and you can probably use whatever to cover the lead, but I had these things at hand.
- Polytek EasyFlo 60 Liquid Plastic
- PVC Plastic Heat Shrink Tube F/W:95mm
Then I printed a 3D clamp (ABS, 30% infill) that has two very long M6 110mm hex bolts going through it.
- M6 110mm stainless steel hex bolt
Finally adding some common furniture anti-skid rubber pads to both the clamp and the lead to avoid the lead sliding in the clamp.
