Dwayne
my dump trailer is wired to its own esc so is the tarp. 3 esc's in the cab the truck esc is the main one with all 3 wires plugged into rx the dump and tarp esc have the red wire's pulled and taped. right knob on the dx9 dumps the bed and a 3 way switch works the tarp. try a truck with out the mfu |
lol..i don't have a truck without a mfu unit in it ..
Could you not just split off your power leads and run a separate ESC for the dump removing the red wire on the servo plug as Mark mentioned? I don't have any experience with MFU stuff but that would eliminate it from anything related to the dump.
i do have a separate esc for the trailer and it has its own power supply also a nimh battery but i need to put it on a 3 position switch on my dx7 and i have no idea how to program it and which switch to use .so i plugged it in one of the ports on the truck receiver in aux2 and there is a switch on the radio that is labelled aux2 and when i flip it .nothing happens and the esc is flashing red ..so i am not sure but it looks like i need to the esc to show a solid green light
You've tried a servo eliminating the esc for now? If everything else is working there must be a setup issue with the TX. I don't have a DX7 but I do have several other DX?? radios. This should be an easy hookup for you so something simple is being overlooked.
