Old 04-06-2016, 01:03 AM
Default Re: Hydraulics
Yes, the brass ends & copper tube is soldered together... my JD850 is brass ends & brass tube, pressure @35bar, you won't be running that high on your loader.
Premacon has a nice hyd kit available for pump & valves, you'd need 3 valves... don't buy Magom's pump & valve set up, just looking at it gives me the shivers. Plumb your loader with 4/2.5mm fittings & hose, should give you good flow speed with 18mm bore cyls on the loader arm & bucket, 14mm bore for steering.
There's the cheap way to do things & maybe it works ok, depends on your expectations I guess... or spend a little more & do it right the 1st time & have it work awesome!
