Old 04-06-2016, 09:22 PM
Cooper's Avatar
Cooper Cooper is offline
Yeah that is one nutt eater that may be a little chewy for pot pie!!!
Started on sides, this time I milled two pieces at once. So,,, both sides should be identical. Have to see when I get to other pieces if they are. Always something just a tad off. Angles were 10 degrees on bottom of bed staying with the frame at10 degree. Then other angles were 11 and 21 (respective of 90). Just used angle blocks in vice and milled vertical while clamping pieces together. 3/16 edges and middle with 1/4" vertical pieces to give some depth relief without having to do much milling.
Old 04-06-2016, 09:35 PM
Wow! You actually know what angle you machined that stuff at? I'm not that sophisticated. I just squint one eye, tap it with a hammer and call it good.... Probably why I can never build the same thing twice....
Lookin good! I like that table too!
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
