Old 04-08-2016, 11:42 AM
JAMMER JAMMER is offline
Default Re: Morpower 3 way valve
If you look on the back of the valve there is a flow adjustment. It is a screw that you turn in and out. Ed
Old 04-10-2016, 08:19 PM
gauthib12 gauthib12 is offline
gauthib12 is on a distinguished road
Thanks Ed, I tried adjusting, still no luck so I took the whole block apart...will post some pics ..I tried blowing out the holes with a needle tip and there was some tiny pieces of aluminum, which I suspect came from the pump break in..not sure but I hope this is the problem, I did read Joe's thread one point he mentions even the smallest specs of dirt can cause problems...I will have to reassemble now for another test...fingers crossed...welcome to any other input...
Thanks..
Old 04-12-2016, 07:52 PM
well no luck, still the same problem Puzzled... with the valve in the neutral and pump running, just with the lines off the cylinders oil is flowing out of both lines ?? this does not seem normal...when I rotate the valve by hand I am getting oil flowing out the top of the block around the valve...definitely not normal..! anyone else on here have the morpower valve block?
