Old 04-11-2016, 09:22 AM
Hwheeler1973 Hwheeler1973 is offline
Hwheeler1973 is on a distinguished road
Default Re: My first Semi build, KW W900L
Some frame and chassis setup. I'm using Lesu axles and single airbag suspension. Don't mind the super sized tires! I only used them to get things going in my mock up!
Old 04-11-2016, 09:28 AM
On to the scale motor and motor/tranny setup. As for the scale motor, I've seen some guys use an arm mounted to the bottom of these as a go between from the servo to the steering. I wanted to do something different tho. I used a low profile servo and mounted it inside the motor.
[IMG] [/IMG]
Old 04-11-2016, 09:33 AM
Im using an Axial, rebuildable, 55T motor and a Veroma Models 3 speed transmission. Very nice setup! Everything fits down inside the rails nice and neat!
[IMG] [/IMG]
Old 04-11-2016, 09:40 AM
I got this body through Shapeways. It was designed by Goose19. I gotta say, he did an amazing job on the CAD design!
[IMG] [/IMG]
Old 04-11-2016, 09:48 AM
And now what I've got so far for my LEDs. Both of these bumpers came from Russ at True Scale. He makes some awesome stuff! All of the LEDs that are lit up are 1.8mm.
[IMG] [/IMG]
Last edited by Hwheeler1973; 04-11-2016 at 09:52 AM. Reason: Uploaded the wrong pics
