Old 04-11-2016, 11:25 PM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
Originally Posted by crawler07 View Post
Superb work Sir! I feel I have learned a ton from you and a couple others on this build I appreciate you all posting for all us noob's. What do I search on Princess auto site to find those cylinders if you don't mind sharing.
Thanks!! Glad you are learning something from this build, I'm learning from it too!! LOL I would say most of us on here have things to learn and if we share what we learn (good or bad) then hopefully we can all learn a thing or two from each other. This forum is loaded with some very talented people building models far more complex and interesting than what I build so be sure and check out all the older builds as well!!
The air cylinders I'm trying are not from Princess Auto , the pump and valve are but the cylinders are from Automation Direct
(Double acting / double end mount)
http://www.automationdirect.com/adc/...cting/A20060DD
http://www.automationdirect.com/adc/...n.%22)&start=0
