Thats a great looking actuator you built there ,I've had my share of drifting servos in the past ,you just need a better esc ,something like this should work ,brushed esc http://www.amazon.com/Turnigy-20A-BR...rc+esc+brushed
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
I don't believe that ESC has reverse in it, which you would need. The use of a servo control board can be done but it needs the pot replaced with correct resistors and even that sometimes is hard to get it to zero out.
If you only need to switch the power on for one direction and then power on for reverse, simple Pololu RC Switches can be used. Jim |
