Old 12-27-2010, 10:47 PM
td9clyde td9clyde is offline
Dozer Builder
Default Re: My new Lowboy
yea that means Travis won't haul my builds around they are all heavy weights :P
Old 01-16-2011, 01:47 AM
Here are some update pic's of the new trailers.
Thanks for looking.
Old 01-16-2011, 02:13 AM
Dreamweaver's Avatar
Weaver Of Dreams
Looks good Travis. Is one of those mine!!
It looks like that plastic is easy to use. Rims look good as well.
I can see one thing though. I am not sure if you overlooked this or just want to do something different. Generally on these trailers the 4 frame rails sit flush with the wood deck. I noticed that the cross members sit flush with the frame rails so when you deck the trailer the frame rails are going to either be covered or sit lower than the deck. If it were me I would cut the cross members down the same amount as the wood decking material.
Just my opinion. You might have something else in mind.
Have you figured out the sag issue yet, you mentioned making a tension system.
-Mike
Mike "DREAMWEAVER" Johnson
Old 01-17-2011, 02:39 PM
SmallHaul's Avatar
Great looking trailers Travis. Nice design.
Scott
"No load is too Small"
Old 01-17-2011, 06:54 PM
Originally Posted by sparkycuda View Post
Followup on wheels - did you make them from PVC pipe fitting or turn from something else? Very good looking! I'd say your "experiment" with lathe and rotary table was a resounding success. Now, just find a CNC machine and run those babies out in mass!!
Thanks Ken they are delrin they started as a 3 ft x 2in rod and I wish I had 100 more of the rims.
Originally Posted by Tamiya Cowboy View Post
Very cool Travy were do I put my order in for one.. Not joking..
Thanks Paul we will have to see how it turns out with the neck on it.
Thanks Scott I just wanted to try some thing different and the plastic is easy to work with.
Thanks everybody for looking.
Old 01-17-2011, 07:05 PM
JAMMER JAMMER is offline
Thumbs up Re: My new Lowboy
Travis good looking lowboy and I like the quad axle. How wide is it and are those plastic wheels or aluminum they look good to?
Old 01-17-2011, 07:15 PM
Thanks Jammer it is 7 7/8 in wide and it will have another 3/4 to an inch on each side when the outriggers are folded out. The rims are one piece delrin with bearings in the rims.
Old 01-17-2011, 08:03 PM
That won't be wide enough for my machine it 12 niches wide at the outside of the cats. I guess after I get every thing else built I will have to build a beam trailer to haul it. You have done a nice job so far and the wheels look real good. Ed
