Go Back   RC Truck and Construction > RC Truck's Vehicles Picture Gallery > 1:1 Your Semi's,Trucks and Equipment
1:1 Your Semi's,Trucks and Equipment Here is a spot to share your 1:1 that you drive and or operate.
Old 04-23-2016, 03:25 PM
Default Re: Something new to rc
Thanks guys.
Acadieman, the drill is a double shoot, two 1" lines going to each shank/seed boot. One line fertilizer, exits seed boot in the middle of the seed row, the 2nd line is seed coming out either side of fertilizer (paired row) half an inch above. The seed boots are spaced 12" apart.
I had a good week here, sowed 900 acre by Friday 2pm... I need to spray burn off (glyphosate) to continue seeding durum, but yesterday & today it's too gusty for that! Fricking weather. Talking rain/snow here Sunday/Monday... it'll be Wednesday below the weather cooperates again... so much for getting started early
Hiredman is on the landroller right now, packing down the small rocks & flattening the dirt lumps left by the drill pass... pulse crops are either very close to the ground or right on the ground, the surface has gotta be as smooth & flat as possible to get 'er all in the bin. ...and hopefully not pick a rock into the combine, that would be bad & expensive.
